07 surburban headlight removal
Old Jan 24, 2007 | 3:01 PM
1604neil's Avatar
Default 07 surburban headlight removal
can anyone help me i have a 07 surburban i want to put the piaa bulbs but how do i take off the headlight i tried i removed two screws and the light came loose on the top part but not the bottom.
Old Jan 25, 2007 | 1:43 AM
engine2's Avatar
Default RE: 07 surburban headlight removal
Welcome to the forum. I would post this question in the suburban or tahoe section of this forum and you should get an answer. I have not removed mine so I do not know.
Old Jan 25, 2007 | 5:12 PM
1604neil's Avatar
how do i take off the headlight from a 2007 surburban a want to put piaa light bulbs
Old Feb 16, 2007 | 5:37 PM
John86's Avatar
Callout
Component Name
[ol][/ol]
Preliminary Procedures
[ol]Remove the 2forward wheelhouse liner screws.
Remove the 2washer container push pins.
Open the hood.
Remove the 6upper fascia bolts right to the hood latch mechanism.
Remove the lower rear fascia bolt from the support bracket.
Loosen the 2fascia to fender bolts from under the fascia.
Pull the outboard end of the front fascia straight outboard until it disengages from the fender attachment bracket.
Pull the fascia forward and downward to allow enough clearance to remove the headlamp assembly.
Loosen the lower outboard attachment bolts.
Remove the 2upper headlamp bolts.
Grasp the headlamp at the upper inboard and lower outboard side and pull the headlamp forward to disengage the locating tab.
Pull the outboard side of the headlamp forward until the 2locating pins disengage from the radiator support.
Disconnect the forward lamp harness connector. [/ol]
Old Feb 16, 2007 | 6:29 PM
1604neil's Avatar
thanks for the info ill give it a try
garyv990
Feb 11, 2015 9:52 PM
warlok
K5 Blazer
Apr 27, 2008 7:46 PM
Classical Glass
Jun 10, 2007 1:43 PM
JasonKaw
Feb 11, 2007 11:27 PM
RTillery
Jan 6, 2007 12:18 PM
