1.72" intake heads with 600 cfm edelbrock carb?
Old Jun 6, 2010 | 10:27 PM
stlhedr29's Avatar
Default 1.72" intake heads with 600 cfm edelbrock carb?
I have a '73 sb350 with 4 bolt mains and dont have a lot of money right now to build it nice. What would happen with the origanal 1.72" heads with a edelbrock performer intake and 600cfm edelbrock carb.?
Old Jun 6, 2010 | 10:29 PM
stlhedr29's Avatar
I have some 194 heads but they need a good valve job and guides to make them work.
Old Aug 4, 2010 | 8:29 PM
Screacher's Avatar
You should be able to jet the carb to set it up ok.
Then, when you get more money, upgrade your heads to flow more air.
Old Aug 4, 2010 | 9:08 PM
maxxman04's Avatar
the 600 carb won't need adjustment or rejetting with the heads. it'll run a bit stronger than a stock motor, since you're running stock cam. a bigger cam when you do upgrade the heads is a good idea. quite a bit more power going that route.
Old Aug 4, 2010 | 10:06 PM
Screacher's Avatar
If you are going to start changing carbs, etc, use this as a starting point:
Engine Displacement x Max RPM ÷ 3456 = Carburetor CFM Requirement at 100% Volumetric Efficiency
If any of that confuses you, (like volumetric efficiency, also known as VE),you can google it, and start learning the basics.
You would be surprised at what you can do with various sizes of carbs...but you will gain more satisfaction by making a decision based on personal knowledge.
Hint: don't try to learn it all at one time...take it in small bites...
Good luck!
AWDmaster
Jan 20, 2014 4:49 PM
Onyxia
Sep 2, 2013 6:17 PM
DSMissed
12
Feb 24, 2012 10:55 PM
shipma2
Feb 13, 2012 11:34 AM
gianelli280
Nov 2, 2009 6:19 PM
