1963 Chevy C10 Brake Bleeding
Old May 24, 2009 | 10:19 AM
The Wiz's Avatar
Default 1963 Chevy C10 Brake Bleeding
Recently purchased a 63 Chevy C10. Straight 6. Drove it home. Following the weekend when the truck wasnt driven and in an attempt to go to work on Monday, the brakes went to the floor.
Upon further search the Master Cylinder fluid level (which has no booster) was below the entrance to the brake line. My inquiry is regarding resolution of this issue.
Is this simply a air in the line and need of bleeding issue? Pls advise as to also the bleeder valve (each wheel) and if I would need to break this down by taking each wheel off.
In advance, I thank you.
Not "The Wiz" of car maintenance
Old May 24, 2009 | 5:43 PM
The Wiz's Avatar
Default 1963 Chevy C10 Brake Bleding
Truck has original drum brakes.
Old May 24, 2009 | 6:25 PM
old dog's Avatar
Default to the floor
check for any leaks,if not lube the bleeder's on the wheel cylinder's down will some kroil penetrant .fill the waster cylinder and try to bleed the furthest bleeder .and so on .if they break off then you have to tear down and replace .!
Old May 25, 2009 | 11:26 AM
The Wiz's Avatar
Default 1963 Chevy C10 Blake Bleeding
Kroil Penetrant? Where can that be obtained?
Old May 25, 2009 | 12:48 PM
old dog's Avatar
Default kroil
http://www.kanolabs.com/ lot of place's sell it but their is their web site
Matt83C10
Jun 27, 2013 7:42 AM
The Wiz
Mar 27, 2009 8:17 PM
yubacitychevy
Jul 22, 2007 10:54 AM
mute_voice
Jan 16, 2007 7:23 PM
