1984 z28 Camaro
Old Nov 14, 2016 | 1:57 PM
Bry10's Avatar
Exclamation 1984 z28 Camaro
So my camaro has a 350 small block 5.7 liter with a edelbrock 1406 on it it worked fine then i parked it for about a week and a half and now it just dies when I drive it i lose all power then backfires black smoke occasionally flames it dis while driving about every 5 mins any ideas what could be wrong????
Thanks
Old Nov 16, 2016 | 10:06 PM
autowiz's Avatar
distributor problems perhaps? take off the distributor cap and turn the rotor by hand. it should turn a little bit smoothly under light spring pressure and return all the way back when you let it go. This is your mechanical advance. The shaft in the distributor gets gummed up and the springs and weights wear. If your mechanical advance feels loose or sloppy then you can take the rotor off and inspect the weights and springs. If the mechanical advance drags and doesn't turn smoothly then the distributor needs to be removed and the driven gear pressed off so the shaft can be removed and cleaned. Or just replace the distributor.
Edlebrock carbs don't have a power valve so the only way you would get a condition with an edlebrock where you are dumping fuel is like if the floats sank. Electric fuel pumps can hurt carbs by constantly trying to send so much more volume than they need.
