1990 Chevy Lumina
Old Aug 8, 2006 | 1:26 AM
yakima's Avatar
Default 1990 Chevy Lumina
When I press the gas pedal the engine is hesitating. There have been several times recently that the engine has even died while coming away from a stop sign or stop light. When I come up an incline on the freeway the engine is pinging until I let up a bit on the gas pedal. I just put in a new overhauled engine 3000 miles ago. I do not understand what is going on.
Old Aug 8, 2006 | 9:37 AM
Nomad76lj's Avatar
Default RE: 1990 Chevy Lumina
could be a few things like your cat or your feul pump i would at least look at thatstuff first.
Old Aug 12, 2006 | 4:05 AM
yakima's Avatar
I replaced my fuel pump 2 years ago and the pump still has very good pressure so I don't think that is the problem. I do not understand what you mean by "cat". Please define the expression.
Old Aug 12, 2006 | 12:07 PM
Nomad76lj's Avatar
catalic converter. its before the mufler in the exust system
Old Aug 13, 2006 | 12:16 AM
kcb37's Avatar
If it is pinging it could be a knock sensor. I don't know if that would make it stall or not though. Untill you said that it sounded like it was just timing. If you timing chain was not lined up it could do that. The knock sensor could do that too. It controls the timing too. It will change it depending on the gas in the car. If you run a higher compression it will a lower octane will want to preignite. The different octane's are not nessesarily better gas, just a higher "heat rating" (sorry I can't spell). The knock sensor will change the timing if it wants to preingnite. But if it is bad it could be completley haywire, or I would say try mid-grade. Is your engine light on?
Let us know.
Chev98
Apr 5, 2013 6:25 PM
tripovermyego
Apr 11, 2011 5:31 PM
jhplove737
Jul 18, 2008 3:03 PM
allthatufear
May 2, 2007 11:21 AM
yakima
Aug 13, 2006 12:20 AM
