1993 GMC Sierra 1500 350 Engine!!! Timing!!
Old Jun 15, 2010 | 7:24 PM
Robertv34's Avatar
Default 1993 GMC Sierra 1500 350 Engine!!! Timing!!
Problem: Trying to set timing! Timing was already off. So I asked a friend to walk me through the steps and I am still having problems. Ok so first off I set the timing mark thats on the crank to the first mark on the clip that conects to the timing chain cover. So im guessing thats negative 1 degree. then I started it and steped on the gas to drive it and it starts to bog down. I parked it and I see that it advanced timing alot???? Is there a timing advancer on these trucks? Like a vacum hose or chip to pull out and set the timing then reconect it?
Old Jun 17, 2010 | 5:51 PM
72c10gunn's Avatar
Ther is a wire you have to disconect to set the base timing, im not sure which one though, It will specify in a manual if you have one.
SpunMufflerBearings
Jun 30, 2010 11:57 AM
MissElieMae
Mar 18, 2009 4:31 PM
gmc1500
Aug 7, 2007 11:23 AM
koticimage
May 3, 2007 9:30 AM
