1995 c-1500 electrical issues. Key won't turn off engine unless I push on the brake.
Old Sep 25, 2016 | 1:30 PM
chutchinson's Avatar
Default 1995 c-1500 electrical issues. Key won't turn off engine unless I push on the brake.
Turn off key to shut engine off and it will not shut down until I push on the brake pedal. Starts right up great. Have to pull the power wire off of battery or battery goes dead in an hour. Radio has no power yet the fuses all check good. When stepping on brake the volt meter on the dash goes way discharge. I have unplugged the brake systems three gang plugs under hood. Everything else seams to work fine. Help
