1997 350 engine problem
Old Feb 23, 2015 | 12:25 PM
mholcombe71's Avatar
Default 1997 350 engine problem
I have a 97 K1500 with a 5.7L 350. Not long ago it sat for about a month. After fixing the issue that caused it to sit I changed the fuel filter and made sure the fuel was good. It started right up. After driving for about 5-10 minutes it just quit running. No check engine light. The fuel pump is relatively new and is working fine. It will not start back up until it sits for a little while. Then the same thing happens again. Changed the MAP sensor and it still does this. I'm at a loss.
Sparky Sparks
Dec 4, 2020 10:58 PM
spaulmiller
Oct 7, 2009 12:01 PM
mml47
Nov 10, 2008 6:26 PM
joshm
Sep 22, 2008 2:10 AM
rockhorsemen
Apr 2, 2008 12:37 PM
