1997 S10 2.2L Exhaust/Flex Pipe Gasket Question
Old May 13, 2017 | 11:45 AM
Stephen Jeffreys's Avatar
Default 1997 S10 2.2L Exhaust/Flex Pipe Gasket Question
Hey guys, thanks in advance for your time.
Inherited this baby, did a bit of work on her yesterday to get her running. Found exhaust leak at mani/Flex Pipe flange, not sure if the gasket or flex pipe is the culprit. Pulled the flex and only a metal 2 bolt flange gasket (old but in tact) between the two. No donut needed? I broke one of the bolts off in the mani flange (even though a full day of liquid wrench several times) so pulled mani. Will get that out. Flex pipe has small cracks and flange moves very freely, braid damaged. Pics attached.
My questions:
Is that metal gasket the only gasket needed?
Should i replace metal gasket with the one i bought?
Is my flex pipe broken? I'm an exhaust noob.
Old May 22, 2019 | 7:00 PM
Kennyboy254's Avatar
Default Flex pipe fix?
My questions:
did you ever get this fixed if so did you have to replace the flex pipe ? Does it come off separate or do you have to take whole muffler off and replace?
