2001 Suburban brake problem
Old Mar 5, 2012 | 8:07 AM
ramon's Avatar
Default 2001 Suburban brake problem
The anti-lock system makes wacky noises and the pedal feels funny only when I'm braking below about 5 mph. Any thoughts about a fix?
Old Mar 5, 2012 | 9:51 PM
EinST's Avatar
Welcome to the forum. The signal from a wheel speed sensor is probably dropping out. This simulates a wheel locking up and causes the ABS to engage. You'll want to get that serviced. If it can be reproduced readily, they'll hang a scan tool and figure out which one. Otherwise, things get interesting as far as diagnostics go.
Old Mar 6, 2012 | 10:22 AM
ramon's Avatar
Thanks, I guess I'll have to bite the bullet and take it to the big bucks store.
Old Mar 6, 2012 | 6:31 PM
EinST's Avatar
You're quite welcome. Hope it's nothing major.
Old Mar 7, 2012 | 12:22 PM
EinST's Avatar
Originally Posted by suvyush
even i think it is better to take mine to their and get repaired right? because i am facing the same problem.
Good for you. Now, quit wasting time pushing that "Mercedes Intake" crap.
P.S. Oh, it's now "Car Performance Chips," is it?
Old Apr 13, 2012 | 3:56 PM
burbanman65's Avatar
Default I might have the same issue
New member to this site and have a 2001 Suburban I really like. I had the parking brake fixed several years ago and since than the ABS and Parking Brake light is on most of the time. Didn't seem to bother anything so never fixed it. Now when I am braking I get this pulsing in the pedal along with vibration from the front wheels until I slow to a stop. Checked the brake pads and they are good. Is this the ABS system malfunctioning?
Old Apr 13, 2012 | 4:19 PM
EinST's Avatar
Welcome to the forum. The ABS is disabled when the ABS warning indicator is on. Thus, I suppose the ABS warning isn't actually on during these incidents. Get it serviced (at least get it scanned and go from there). As heavy as the Suburban is, I'm surprised that you've been ignoring an issue that has to do with the brakes.
Old Apr 13, 2012 | 9:17 PM
cleveland63b's Avatar
sounds like it wasnt fixed if the light was on after the repair. If you don't have quick access to a scanner I'd start at the rear wheels and look for anything damaged from the parking brake "fix"
Old Apr 13, 2012 | 9:31 PM
Thanks for the input. I'm sure there was a problem after the brake repair but figured it was a senor issue and just ignored it as we weren't driving it that much. I'll get it checked
Old Apr 16, 2012 | 9:08 PM
tbwoods's Avatar
I had a similar problem. when stopping sometimes at slow speeds, ABS would go on even though it was dry out and no wheel skidding. I was told by my mechanic that as the front wheel bearings wear, the ABS sensor on those wheels erroneously causes the ABS to go on. I pulled the ABS system fuse and ran for a while with no ABS for about 2 years . problem went away, but of course I had no ABS brake function. Then my front wheel bearings started to go noticibly bad. I replaced them on both sides. Immediately after that, I plugged the fuse back in and the pulsating at low speeds no longer occurs. I'm sure my problem was front wheel bearings going bad.
