2002 cavalier engine light
Old May 29, 2007 | 10:28 PM
coling659's Avatar
Default 2002 cavalier engine light
So, I started my car after work today and the engine light has been on since. car is running fine, not over heating or having any type of engine problems. Oil change is not due for well over 1000k. Do I really need to spend 100's ofdollars at the shop or is there cause for concern?...any help would be appreciated...thanks
Old May 30, 2007 | 9:37 AM
dnml848's Avatar
Default RE: 2002 cavalier engine light
If the check engine light is on,I would suggest going to either Autozone or Advanced Auto Parts and have them run a free diagnostic on the vehicle. It could be an oxygen sensor that is bad or something along those lines. Let me know if this helps!
Old May 30, 2007 | 11:10 PM
Chev007's Avatar
agree with the above post have it checked.. it could be that its time to replace your chevrolet oxygen sensor with a new one. also check your Air Flow Sensor.. just give us an update regarding this matter.
Old May 31, 2007 | 7:33 AM
golfer's Avatar
ORIGINAL: coling659
It's up to you ... there's a problem existing and you can simply ignore the light , keep driving and hope it fixes itself ....
or
check the gas cap to see if it's there and on properly ...
or
go to the mentioned places to have them pull the codes for free.... then decide.
Old Jun 5, 2007 | 11:16 AM
squir3lz's Avatar
Yeah just go get a free digonostic .
Nicole
Dec 28, 2017 7:21 PM
jdebrabander
Feb 4, 2015 10:26 AM
Bulldog9539@gmail.com
Sep 4, 2011 1:54 AM
