2002 tahoe door lock problem
Old Apr 24, 2014 | 8:21 PM
Snelsone's Avatar
Default 2002 tahoe door lock problem
When I push the button on the door and on the key fob I can hear a click in the fuse panel but nothing happens. Thoughts?
Old Apr 25, 2014 | 11:59 AM
Are you talking about one door or all of them? If you are talking about only one door then, there is an actuator inside the door and it is connected to the lock mechanism by a rod. This rod is held on to the actuator and the mechanism by plastic clips. These clips break over time and need to be replaced. This is where I would start looking.
Old Apr 26, 2014 | 10:27 AM
Snelsone's Avatar
Default It's all the doors
None of them seem to be doing anything I'm hoping that means it's a fuse. It also has an aftermarket alarm on it which might not be helping.
Old Apr 26, 2014 | 6:44 PM
check the lock and unlock fuses in the left I/p fuse panel.
Fred Nunley
Jul 25, 2014 2:10 PM
lnewcomer
Mar 27, 2012 7:20 PM
forsakin
Aug 9, 2010 9:46 AM
Mastiff
Jul 12, 2010 8:39 PM
jjowers19
Mar 8, 2010 6:43 PM
