2004 Cavalier clutch issue
Old Dec 25, 2020 | 2:36 AM
tim_james2's Avatar
Default 2004 Cavalier clutch issue
The car was purchased and would not down shift at all. The lady parked the car and I finally got under the hood and started checking things out. The clutch master cylinder was replaced and we refilled the resevoir and staarted bleeding the clutch. Once all the air was removed the clutch allowed you to shift properly, the car was not driven immediately. About an hour later the owner showed up and wanted to drive the car. She went out and started the car and the clutch would not allow her to put it in gear, you could hear he gears grinding. I called my ASE mechanic friend and he came over and we dtermined that AIR is getting into the clutch system somehow, but it is not leaking fluid anywhere. My question is. How or where can air enter the clutch sytem? The seal on the resevoir appears to be in very good condition and when we bleed the system we are not getting any hydralic fluid into the bleeder pump thaat we are using. Any help would be greatly appreciated.
Old Dec 25, 2020 | 6:12 AM
can you shift thru the gears with the engine off?
Old Dec 25, 2020 | 7:07 AM
tim_james2's Avatar
No sir, it will not go into gear when shut off or running.
tim_james2
Jun 29, 2020 3:23 AM
endo
Camaro
Dec 7, 2009 9:17 PM
ryank
Mar 29, 2009 4:21 PM
speedracer22
Jan 3, 2008 8:32 PM
pissonadodge
May 23, 2007 7:35 PM
