2005 Chevrolet Truck Silverado 1500 2WD 4.3L FI OHV 6cyl "IGNITION ISSUES"
Old Jul 18, 2021 | 8:43 PM
Marebito's Avatar
Default 2005 Chevrolet Truck Silverado 1500 2WD 4.3L FI OHV 6cyl "IGNITION ISSUES"
Posting on my Uncle's behalf.
It's a 2005 Chevrolet Silverado 1500 2WD 4.3L Fl OHV 6cyl and is having ignition issues. We'd like a good starting point on how to fix and check things off.
CODES:
P0016: CRANKSHAFT POSITION CAMSHAFT POSITION CORRELATION BANK 1 SENSOR A
P0420: CATALYST SYSTEM EFFICIENCY BELOW THRESHOLD BANK 1
P0446: EVAPORATIVE EMISSION SYSTEM VENT CONTROL CIRCUIT
P0016: CRANKSHAFT POSITION CAMSHAFT POSITION CORRELATION BANK 1 SENSOR A (I NOTICED IT CAME UP TWICE ON THE SCANNER)
P0102: MASS OR VOLUME AIR FLOW A CIRCUIT LOW
P0122: THROTTLE / PEDAL POSITION SENSOR / SWITCH A CIRCUIT LOW
P0300: RANDOM / MULTIPLE CYLINDER MISFIRE DETECTED
P0420: CATALYST SYSTEM EFFICIENCY BELOW THRESHOLD BANK 1 (CAME UP TWICE ON SCANNER)
P0446: EVAPORATIVE EMISSION SYSTEM VENT CONTROL CIRCUIT (CAME UP TWICE ON SCANNER)
P0506: IDLE AIR CONTROL SYSTEM RPM LOWER THAN EXPECTED
Any help to get it running is greatly appreciated. Thank you.
OnDaGround
Feb 1, 2019 12:23 AM
rabbit0102030
S10 & Blazer DIY and Useful Threads
Mar 5, 2014 7:36 PM
Slammajamma
Sep 24, 2011 2:56 PM
mrht
25
Jul 13, 2009 10:35 PM
rottman
Nov 19, 2008 5:13 PM
