2006 malibu steering and wheels
Old Sep 25, 2015 | 12:09 AM
Mattman12's Avatar
Default 2006 malibu steering and wheels
I have a 2006 malibu. I recently replaced the outer tie rods. They were bad and wobbly. So with that said i had a little wobble in the steering wheel almost like a pulsing. I replaced the tie rod ends its still doing this the inner tie rods are fine. Some times it smooths out sometimes it just does it all the time. When im driving the steering wheel kinda jerks back and forth like a quarter of inch its not real bad but enough to feel it passengers feel and enough to annoy me. When i break it seems to do it worse. As im slowing down. If anybody has had this issue some info would be spectacular im kinda baffled at the moment.
Old Sep 25, 2015 | 8:21 AM
you may have 2 separate issues causing the concern.
most times, steering wheel shimmy is transferred into the steering wheel from the front tires when cruising and the front rotors when braking.
Old Sep 26, 2015 | 5:45 PM
Mattman12's Avatar
Default 2006 Malibu steering and wheels
Thanks for that info turns out had a bad belt on the front drivers side Tire I usually check the small stuff first. I over looked that. So it's fixed rides smooth again
Sebastiaan Van Den Berg
Apr 28, 2013 8:02 AM
cazador223
May 16, 2008 3:09 PM
SteveI
Sep 7, 2006 1:59 PM
