2013 1500 4x4 won't start
Old Mar 4, 2018 | 11:52 AM
Killerwoody's Avatar
Default 2013 1500 4x4 won't start
The truck turns over but won't actually run. Yesterday it did it too but after a few mins it started anyone have any idea?
Old Mar 4, 2018 | 12:03 PM
probably the check valve in the fuel pump assembly is bad. it is letting the fuel bleed back into the tank. Then when you try to start it has to prime the system before it will run.
Old Mar 4, 2018 | 12:16 PM
Did some reading could it be the fuel pump relay module ?
Old Mar 4, 2018 | 1:50 PM
The relay must be good since it starts after cranking for a minute or two.
Old Mar 4, 2018 | 2:02 PM
Apparently its the ECSM or ESCM... that's above the spare tire. I would start after a few mins now it's not... When I turn it over I smell fuel like it's pumping. Under the hood I hear a click on key turn but once you leave the key on a minute the check engine light stays on. I got a warranty so it's going to the dealership tomorrow.
Old Mar 4, 2018 | 3:58 PM
Crazy I put the pedal to the floor and it started... good bit of black smoke rolled out.
