2014 Impala Limited LTZ
Old Jan 26, 2018 | 5:52 PM
TOMMILTZ's Avatar
Default 2014 Impala Limited LTZ
the rt rear corner of sunroof sticks up* fortunately not leaking but is there an easy adjustment for that?
Old Jan 27, 2018 | 10:26 AM
the glass is bolted to the track with 4 screws. loosen the screws and adjust the glass position. the front edge should be flush with the roof, the rear should be 1mm higher than the front.
Old Jan 27, 2018 | 1:03 PM
TOMMILTZ's Avatar
Thanks for the info ! you seem to be the only one that replies and I appreciate you for that. Nice truck by the way!
My youngest son has a 2006 ram 2500 12 valve common rail 6 speed with twin turbos, I once had a mid 11's camaro and I thought that was fast.
These diesels are impressive. Thanks again.
Old Jan 28, 2018 | 12:21 PM
yep, it is amazing what diesel turbos are putting out these days.
