2015 Suburban in shop at dealership under warranty
2015 Suburban with AFM/DOD with163k on it finally started ticking. Thank God I have a warranty that came with the vehicle when purchased. The chevy dealer is saying it needs new lifters and a cam shaft and is charging the warranty company after engine tear down to make this determination 9k for the repair and the warranty company has agreed to pay for it. This is after the torque convertor began to shutter and I took it to the dealership, and they said I needed a new transmission. Well, the warranty company shipped a remanufactured one to us so. It is installed and programmed and I am just waiting on the engine repair. I have looked it up and the kit and camshaft to delete Afm is less than 1200 if I remember right. My stepson who is a mechanic said they used to do this all day long for 2k. He said for 9k it sounded to him like I might be getting a new gm motor. We shall see. I will keep this post updated when I know more.
I have used nothing but napa gold filters and Castrol high mileage synthetic when I bought this vehicle with 145k on it so. I took care of it like it should have been.
Well, I think the issue may be that you didn’t actually ask a question - you just told us what was going on. I saw it the day you posted, but had no meaningful commentary to add, aside from thinking you were very lucky to have a warranty paying for all this.
Rednucleus (August 16th, 2024)
Well yeah I went back and re-read it and I did leave out the question. What would the 9k be fore because I am pretty damned sure lifters and a new cam shaft don't cost 9k.
I would just ask the dealer what they are replacing.
Yeah I plan to and I'm not complaining as there's been almost 15k of work done on it from a new "remanufactured" transmission to this motor work.
My portion will probably be less than 500.00 so the warranty definitely helped out and I'm glad the dude i bought it from gives the warranty free with purchase on all the vehicles he sales.
jfmorris (August 16th, 2024)
Well the total bill came to 9,620.76 cents if i rememeber right. My portion after was 201.01 that was for the 100.00 deductible and then 100.00 shipping on the newly remanufactured transmission that they installed and programmed to work.
The motor work invoived replacing all the lifters, the camshaft, various seals, and gaskets, they also determined that the reason the electric fan was still running after the vehichle was shut off was due to the thermostat being stuck open and causing low voltage issue. They replaced the thermostat and the fan does not run after shutting the vehichle off anymore.
jfmorris (Yesterday)
Glad to hear they got you fixed up, and that the vehicle is running like new!
I think I would consider getting one of those AFM disabler dongles that plugs into the ODB2 port to just keep AFM from ever causing an issue again. If I ever buy a newer GM truck with the AFM, that is one of the first things I'll be doing is disabling it.
