2017 suburban tail light malfunction
Old Aug 14, 2020 | 10:12 PM
texasclay's Avatar
Default 2017 suburban tail light malfunction
Hey guys, I feel like I have exhausted my knowledge and about to take the vehicle in to a shop.
2017 suburban LT, 96k miles, stock.
It has showed intermittently “right brake light malfunction” message with rapid clicker on dash for awhile. A few days ago lost all power to right brake light housing (no brake, blinker etc.). Changed bulbs-no fix, checked fuses- apparently there is no fuse dedicated to that light. Plugged the “defective” light housing into the other side- it worked fine. Switched the good one (left side) into the right side- nothing worked.
So I have deduced it must be the wiring somehow (bad ground, chewed line, etc) unless I am missing something obvious? Nothing seems loose/frayed on any of the wires/connections that are visible.
any feedback would be welcomed and appreciated. Thank you!
Old Aug 15, 2020 | 3:55 AM
oilcanhenry's Avatar
Probably have a bad relay or a bad ground.
Old Aug 15, 2020 | 10:13 AM
dtcassist's Avatar
Former Sponsor
The brake light and turn signal power comes straight from the Body Control Module - that's how it knows there is a problem back there. If nothing works on that side, the only thing all bulbs have in common is the ground wire. Time to test for your powers and grounds at the tail lamp connector.
Decohead
Apr 18, 2018 9:45 PM
IB Cristina
Newsletter Archive
Dec 5, 2017 9:32 PM
Steve11
Sep 21, 2017 7:11 PM
SugnyMan
2014 - 2018 (GMT-K2)
Jun 18, 2017 8:03 PM
