Notices
2500hd electrical gremlin?
Old February 10th, 2010, 6:06 PM
maxxman04's Avatar
Default 2500hd electrical gremlin?
2004 gmc (sshhh, close enough) duramax. been having this issue for quite some time. when i first start the rig, the volt meter stays around the 12-12.5 mark for about 30 seconds, after which, it jumps up to the normal mark, lights brighten up, everything works as should. it only does it after sitting overnight. replaced battery, cleaned all connections, replaced alternator. had load test done on system, passes perfectly. amperage doesn't fluctuate or drop, voltage good. there just seems to be a short period, only after sitting overnight, where it takes a bit to get juice to system. rig cranks and starts great. can't find a TSB regarding this, or anyone else who has had this issue. it's not affecting performance at all, so i drive it. just one of them things. ideas?
Old November 12th, 2011, 9:31 PM
chevy51's Avatar
My 03 2500HD has the same problem.Doesn't do it when it is warm outside or the truck is warm.
Old November 13th, 2011, 5:12 PM
EinST's Avatar
The should be normal on the Duramax Diesel. The ECM turns on the glow plugs and intake air heater when cold. Plus, it juggles the glow plug ON times and alternator duty cycles to prevent the glow plugs from overheating (takes just a couple of seconds to reach ~1,800°F).
Old November 13th, 2011, 5:35 PM
jake63's Avatar
The dodge diesel does it to when starting. It is warm air injected instead of glow plugs.
fedsrule
August 28th, 2014 8:45 AM
Jbarnhart
June 17th, 2013 8:33 PM
tobaccoman
February 14th, 2013 3:04 PM
OtherCarASaab
September 25th, 2012 7:44 AM
Zed7TOne
Silverado & Fullsize Pick-ups
January 28th, 2008 7:50 PM
Quick Reply: 2500hd electrical gremlin?
