305 misfiring
Old Aug 31, 2009 | 3:13 PM
marlb08's Avatar
Default 305 misfiring
ive already changed out the spark plugs and spark plug wires i know the carburator is not adjusted right because its too rich and ive tried adjusting it but i couldnt find the right spot so would all of that cause a misfire? if so wat can i do?
Old Aug 31, 2009 | 6:15 PM
Mike Sigmond's Avatar
ROTM Coordinator
Welcome, It could be a bad coil/loose wiring or the timing is off. But if you say your carb is not adjusted right it can be that too. Is this a project vehicle or a stock vehicle?
Old Sep 1, 2009 | 9:51 AM
therewolf's Avatar
Need a little help here, new engine? High mileage engine? Year? Standard ignition for said year or retrofit/upgrade?
Type of carb? Is it stock, replacement or performance upgrade?
Assuming it's a Rochester 2 barrel, try closing the two carb adjustment screws gently, then backing them off 2 1/4 turns. That should put you in the ballpark for normal fuel flow.
Have you pulled the valve covers and looked at the pushrods and rocker adjustment? Sounds like you could have a couple bent pushrods or collapsed lifters.
87caprice718
Jul 29, 2015 5:16 PM
MWRacing
Jan 21, 2015 10:08 PM
hawk265
Sep 27, 2006 3:07 PM
