327 knowledge
Old Mar 21, 2008 | 3:41 PM
3rd_gen_gm_man's Avatar
Default 327 knowledge
i was wondering if anyone could help me i know my way around an engine but as for interchangable parts im still learning and i was wondering what kind of heads will fit on a 60's 327 it has been bored and stroked and all i need is heads and a transmission possibly right now i have a TH350 trans in a buick regal limited and i was wondering if that 327 would bolt up or not any help would be great thx
Old Mar 26, 2008 | 10:12 AM
old dog's Avatar
Default RE: 327 knowledge
depend's on how much compression you want and how much of a dome you have on you pistons ,if they are flat top pistons or dished you can put the old double hump head's with the small chambers (smaller valve's ) unless they have beemn opened up ,or a later model 350 head with a larger chamber from the early 1970's /as far as the transmission if it is an actual buick v-8 trans i do not think it will work .depending on the year gm went with an chevy motor ,all you can do is check the bolt pattern or determine what motor the buick had in it .good luck .
smithca20
Oct 31, 2012 7:52 PM
LS1RatRod
Dec 30, 2011 4:04 PM
Mille Racer 69
12
Aug 5, 2011 11:37 PM
JOEUSA
Feb 20, 2011 1:19 PM
parro
Aug 17, 2008 8:38 PM
