3400 v6 cooling fan ?
Old May 11, 2006 | 7:44 PM
xswinnyx's Avatar
Default 3400 v6 cooling fan ?
A friend of mine has an Olds Alero with the same engine as my Impala, 3400.
I think the car is a 2000.
His cooling fans are not kicking in, I checked the relays and fuses, they are good.
What else can cause this, and where is it located? anybody know?
Old May 11, 2006 | 10:27 PM
Nomad76lj's Avatar
Default RE: 3400 v6 cooling fan ?
the fan is at the front of the motor under the fan cover. it may be a broken wire at the fan. you may have to get at it under the car.
Old May 12, 2006 | 12:39 AM
xswinnyx's Avatar
Thanks for the reply.
I checked the wires and connections too. I was thinking along the lines of a temp. sensor or something. Is it run off the same sensor as the temp. gauge? We had the car running in the driveway, for about a half hour. It was a pretty warm day that day, but the temp. gauge never got over half and the fans never kicked in, any more ideas?
Old May 12, 2006 | 11:58 PM
Nomad76lj's Avatar
you can unplug the plug in the fan run some dummy wires from the fan <just bare the ends of the wires and put them in the plug socket> < dosnt matter what way if you get them the wrong way the fan will just spin bacwards >to see if the fan runs. then if it works it is probly the temp senser.
Old May 13, 2006 | 1:01 PM
xswinnyx's Avatar
Can anyone tell me where the Temp. sensor that controls the cooling fans, on a 3400 V-6, is?
mgnui
Apr 8, 2010 11:29 AM
mgnui
Mar 24, 2010 9:57 AM
92chevysilvy
16
Apr 1, 2009 3:05 PM
92chevysilvy
Mar 12, 2009 9:21 AM
sellersoasis
Nov 5, 2008 5:42 PM
