350 engine won't start, but smokes cranking
Old Jan 9, 2015 | 6:45 PM
rick leddon's Avatar
Default 350 engine won't start, but smokes cranking
Hi
I have a 1996 350 with 292k on it. Today it start right up, but the service engine light was on, drove 10 miles and tried to restart after a few minutes. It cranked for about two minutes, started, but ran very poorly. I drove home it seem to run ok, but after shutting off on the driveway it wouldn't start again, but smoke poured out the tailpipe. Any ideas. Thanks for any help I get.
Rick
Old Jan 11, 2015 | 10:22 AM
Default Checked engine codes
Still haven't figured out what is wrong. The did start, so I took it to O'Reilly Auto to get the codes checked. I have a coolant sensor not reading. Doesn't seem like this would be causing the truck to run poorly and not start at times.
I didn't shut the truck off at O'Reilly's, but when I got home it would start again. It ran poorly and stumbled at times. Does anyone have an idea. Thanks Rick
Old Jan 23, 2015 | 9:34 AM
I went ahead and replaced the coolant sensor and it seemed to fix my problem. Thanks
Old Feb 1, 2015 | 12:10 AM
6.2man's Avatar
You need that sensor to tell ECM how much fuel to allow . Good job
Old Feb 1, 2015 | 3:27 PM
Thanks for the reply. Rick
Old Feb 2, 2015 | 8:52 PM
gearbox's Avatar
Glad to hear you did it right and thanks for sharing.
bigr82
Feb 27, 2014 9:48 AM
missy82tx
Jun 29, 2011 2:30 PM
Paul Seidman
Avalanche
Aug 18, 2010 3:33 PM
mryan_davis
Aug 29, 2009 11:40 AM
bracca
Jul 12, 2009 6:14 PM
