350 starter to flywheel clearance
Old Mar 20, 2007 | 4:38 PM
sbudac's Avatar
Default 350 starter to flywheel clearance
I'm rebuilding a Jeep CJ7 and havea 350 small block LT1 with a 168 tooth flywheel and the new starter I put in only meshes about a third of the way with the flywheel. It has bolt holes for inline and offset starters and I put in an inline type. The clearance when retracted is over 0.3" while specs say 0.1" Would switching to an offset starter nake a difference, if not is there anything I can do about this? The flywheel mounts fine, but the engine was originally mated to an automatic/flexplate. The crank isn't different for an auto (sticks out further in the back) does it? Thanks!
a_plus
Jul 2, 2011 12:20 PM
chase050505
Mar 1, 2011 1:29 AM
LilManDavis
Jun 22, 2008 10:41 AM
Zeke
Sep 27, 2006 2:32 PM
