4L60-E trans issues...
Old Dec 27, 2016 | 6:18 PM
Reeko's Avatar
Default 4L60-E trans issues...
Hey guys, I have a 95 GMC G2500 Vandura conversion van with 170k miles (i believe it has a 4L60e), Has been running great with no issues until just recently. Occasionally (about 1/4 of the time) it will make a grinding noise when being put into reverse or drive right after starting it up. Once the van gets rolling, the noise will stop, and will drive fine (without the noise). I can idle at a light and shift into R without issue.
Park or neutral won't ever make the noise. But when I shift to D, it starts, and I can shift back to P to make the noise go away. Like I said, once it gets moving the noise will totally stop, even when shifting into reverse or idling at a stoplight.
Sounds like it's going to need a rebuild. I'm 250 miles away from home at my folk's place for the holidays. I am fairly certain it will make it back fine, but I definitely want to get it sorted as the plan was to take this van on a long trip.
Any suggestions other than just biting the bullet and rebuilding? Thanks guys!
Old Dec 27, 2016 | 8:41 PM
Rednucleus's Avatar
Check fluid level? Any idea last time serviced?
Old Dec 27, 2016 | 9:57 PM
Reeko's Avatar
Thanks for the reply. Fluid level is normal and appears nice and clean. No idea last time it was changed but I'll be trying it as a last ditch effort
Old Mar 4, 2017 | 5:34 PM
astrocamper's Avatar
I have exactly the same issue with my 1997 chev astro. Have you tracked down the cause of your issue?
Thanks
