4l80e delayed 1-2 shift
Old Aug 19, 2013 | 8:44 PM
Nehemiah Lewis's Avatar
Default 4l80e delayed 1-2 shift
I have a 92 chevy g30 van 5.7 liter with a 4l80e transmission. The transmission has a delayed 1-2 shift on moderate acceleration. All the other gears do fine. The fluid looks great and it has a new transmission filter, tps, and output speed sensor. It will shift fine if you let up on the accelerator pedal. Any help would be appreciated. Thanks.
Old Aug 21, 2013 | 5:53 PM
wrenchtuner1957's Avatar
Sounds like the throttle valve cable may need an adjustment.
Old Aug 23, 2013 | 7:12 AM
This transmission is electronically controlled so it does not have a throttle valve. Any other thoughts or questions?
Old Aug 26, 2013 | 8:15 PM
Default 1,2 shift delay
The only other thing that could be is the valve body. I have seen some where replacing the valve body took care of the problem. I recommend talking to a specialist first.
fptbigtony
Dec 29, 2013 4:12 AM
white03
Oct 16, 2013 12:50 PM
jhboone
Sep 7, 2012 10:16 AM
stadlgi
Oct 6, 2010 11:40 PM
scott_mckinney
Oct 28, 2008 8:59 AM
