5 to 6 lug
I have a 98 Chevy pickup (2wd/v6) with bad tires (15"/5lug) and rear.
I have at my disposal a wrecked 2004 astro cargo van. The van has 16" 6 lug rims and new tires.
Can I swap the rear/axle/tires from the astro to the truck? I know the the differential has the same gear ratio. Also the van axle is 2" wider so I might need to perhaps put a spacer in to reinstall the leaf springs.
I'm also wandering if I might be able to swap the front tire assemblies. Perhaps disconnect the control are nuckles.
Any advise is appreciated. Thanks in advamce
Matt94 (November 13th, 2022)
This truck is worn out and my van is in a lot better shape (besides front end collision)
Also I have eight 16" tires and only two 15". Seems to me the rear might swap over even with the offset differential. Maybe No hope for the front? I got the axle and all dropped from the pick-up so I'll try the swap in the morning.
luc_antonio
October 23rd, 2013 8:52 PM
