69 gmc trouble starting
Old May 19, 2020 | 1:31 PM
Krawler's Avatar
Default 69 gmc trouble starting
I have a 69 gmc with a 350. I pulled the top end off. Cleaned up the heads. New valve seals. Bought and Edelbrock rpm air gap intake and put an Edelbrock 600 cfm carb on it with an accel ignition system. I finally got it to fire up but it will not stay running for more than a few seconds. Ideas?
Old May 19, 2020 | 2:03 PM
kevinkpk's Avatar
600 cfm is a little small unless you just using it for a daily driver. Is this a mechanical or electric fuel pump? I'd suggest pulling the fuel line off the carb see if the pump is staying up with fuel demand.If you are running an electric pump, I'd strongly urge you to put a fuel regulator on it as the electric pump puts out alot high pressure.
Old May 19, 2020 | 2:12 PM
Krawler's Avatar
It is just a daily driver. Nothing crazy. Just wanted a hair more out of that 350 and wanted it to look a bit more appealing under the hood. It is just a stock(possibly original fuel pump) mechanical needless to say.
Old May 19, 2020 | 2:14 PM
kevinkpk's Avatar
If the pump is working as it should, possible the carb float isn't set right. Mechanical will run around 10-12 lbs.
Old May 19, 2020 | 2:50 PM
Krawler's Avatar
I’ll see what the pump is putting out. It ran not bad before I pulled it apart. There was one time I drove it and it was backfiring a hunch but other tha that it ran ok
Old May 19, 2020 | 3:16 PM
kevinkpk's Avatar
'Old school, general rule" with cranking for 5 seconds, you should fill a pop bottle (then 12 oz). Dieing as you posted is lack of fuel, backfiring is ignition
Old May 19, 2020 | 3:57 PM
Krawler's Avatar
I did not know that about the pop bottle. Thanks for the tip
Old May 19, 2020 | 7:47 PM
Krawler's Avatar
So I tried the pop bottle. Counted 5 Mississippi’s and it didn’t even fill half the bottle
Old May 20, 2020 | 7:35 AM
kevinkpk's Avatar
Well, looks like fuel pump time.
mandj23
Sep 1, 2014 12:53 PM
baldana
Aug 6, 2011 1:59 PM
1972GMCSprint
Apr 12, 2007 6:13 PM
