72 monte rear end gearing
Old May 4, 2013 | 7:26 PM
mc7deee2's Avatar
Smile 72 monte rear end gearing
im new to this ok here goes i have a 1972 monte carlo with 350sb/turbo 350 trans stock rear end . I wanted to know what would be the best gearing cause my launch sucks but it pulls after second gets in. I was thinking a 3.73 rear end but idk so if i cant get some advice it would be very appreciated.
Old May 4, 2013 | 9:14 PM
kevinkpk's Avatar
What do you want to do with it?
Old May 4, 2013 | 9:24 PM
mc7deee2's Avatar
Well race on weekends but you know sometime cruising i guess but you know a little import pulls up i wanna be able to launch on em cause it takes till 2nd gets in to start pulling anf
my trans is automatic
Old May 5, 2013 | 12:55 PM
SWHouston's Avatar
To "launch" better, you need to increase your gear ratio.
What do you have in it now ?
Remember, the more turns to the Driveshaft, is going to knock you top end down. Why do you think that 3.73 is the right gear ?
Old May 5, 2013 | 1:46 PM
kevinkpk's Avatar
I'd go with a 4:11
Old May 5, 2013 | 3:58 PM
mc7deee2's Avatar
Idk what gearing i have now. My friend says that 3.73 is good
Old May 5, 2013 | 4:10 PM
Brok's Avatar
Rear wheel drive GM transmission gear ratios Here is a site that can help assist you on your gear ratios for your gear ratio these are the stock versions. I have known people to run them up to 4.10 gear ratio and who put in a 350 turbo with performance rebuild kit and a shift kit. In my opinion most I have known have gone to 3.73 or go down to a 3.42 or 3.23 gears ratio though. It is just what you plan to use it for and how much fun you plan to have with it. If it's a race car I say have fun if you know your stuff and can maintain it well.
Old May 5, 2013 | 4:13 PM
SWHouston's Avatar
You may have 3.73 in it now. But until you're sure, it's really hard to give any recommendation. Are you going to do anything to get your RPM's up ?
Old May 5, 2013 | 4:18 PM
Brok's Avatar
Smile
Good Golf think that pretty much said it all.
Old May 5, 2013 | 5:09 PM
kevinkpk's Avatar
Figure the ratio is take the ring to pinon add them up, and divde them into each other.
