89 454 engine does not turn off please help
Old Jun 22, 2009 | 8:46 PM
bbah111's Avatar
Question 89 454 engine does not turn off please help
hi i am new to this forum. i have a 454 chevy engine and when i try to turn it off it goes from running on 8 cylinders to only 2 and when it turnes to only 2 cylinders than it backfires. i can even remove the key but it keeps on running. the engine has only 47000 miles on it.
thanks
kerim
Old Jun 22, 2009 | 10:59 PM
suzuki-guy's Avatar
Sounds like an ignition switch. Anybody else agree?
Old Jun 23, 2009 | 2:33 AM
Koffietje's Avatar
Thats pretty much all it could be.
There should be a fuse in your fusebox for the ignition switch. Pull it out, if the car stops , then you know what to replace.
Just a question out of curiosity though... how do you turn the engine of then?
Old Jun 23, 2009 | 11:15 AM
bbah111's Avatar
thanks for the help i will try it as soon as i get home.
i have to move the key to on and of a couple of times and then after a while ti turns off.
thank you
kerim
Old Jun 23, 2009 | 12:12 PM
Koffietje's Avatar
definetely ignition switch then. It might even solve itself by just pouring some "grafit" in the key switch. (I dont know the english name really. The product is some sort of lubricant without any oil in it. You also use it to lubricate house door switches.)
Old Jun 23, 2009 | 11:05 PM
bbah111's Avatar
ok im gonna get my ignition system checked
thanks for all of your help
thank you
kerim
Old Jun 24, 2009 | 3:24 AM
cams 98 silverado's Avatar
its called graphite. well... i know its a lubricant and it contains no liquid. i used to use it on my pinewood derby cars. since we didnt have axles, we had a nail and a tire as the drivetrain, so you pour graphite into the gap from the wheel and nail and it makes it glide like nuts. but yea. its powder graphite. works on lots of things.
Old Jun 24, 2009 | 11:14 PM
Gwampa's Avatar
When they brought out all the smog crap for cars 70's we use to leave the automatics in drive and turn off the switch...or leave it in gear with a standard, turn off the switch and feather the clutch...with foot firmly on the brake in either case of course. How high is it idling? And 1Gary's right, where is the timing set?
Old Jun 25, 2009 | 4:36 PM
bbah111's Avatar
it doesn't have a display that shows how high its idling but it runs great.
thanks for all of you help
marcos77
Aug 28, 2017 2:05 PM
Heat Seeker WS6
Sep 23, 2013 9:12 AM
ridgemeadows
Jan 24, 2010 3:27 PM
Mr. Vann
Nov 25, 2009 7:24 PM
