93 4l60e
Old May 29, 2019 | 10:34 PM
Xyang's Avatar
Default 93 4l60e....reverse only no forward gear after rebuild
Rebuild my first 4l60e(1993), new wiring and electronics....also new convertor...i only have reverse no forward gear no matter where you put the shifter. If you put it in D1 and rev the engine you can feel it trying to go in reverse. If i unplug the trans connector and put it in D4 it wants to go but doesnt.....any help
Old May 29, 2019 | 10:38 PM
Irish_alley's Avatar
I'm here for the party
silly question but is the fluid level ok? and what was the old trans doing?
Old May 29, 2019 | 10:55 PM
Xyang's Avatar
Default 93 4l60e
The orginal one i pull out was full of water and transmission fluid mix(no movement in any gear)...so i got a 4l60e from a 93 suburban and built that instead....i put 11 quarts in it dex 3...
Old May 30, 2019 | 12:58 AM
oilcanhenry's Avatar
Did you replace the leaking radiator?
Old May 30, 2019 | 3:31 AM
Xyang's Avatar
Yes....
Old Oct 21, 2019 | 3:02 PM
Xyang's Avatar
I fix it case close.
Old Oct 21, 2019 | 11:35 PM
Rednucleus's Avatar
What was the fix please?
Old Oct 21, 2019 | 11:49 PM
Xyang's Avatar
I forgot to install the front sun gear.
