93 C1500 Silverado - won't start
Old Sep 24, 2014 | 10:54 AM
hippyspec's Avatar
Default 93 C1500 Silverado - won't start
I just bought this old truck. '93 Silverado, 5.7, 2WD, 200k or so.
Once in a while when you turned the key, it would not start. Had to jiggle it a bit, turn back to acc, eventually it would relent and start. When working, you turn the key and it starts immediately, no long cranking or hesitation.
Now it's gone out altogether - it clicks, lights up, but no ignition at all. Battery checks good, starter is good. It will not start in neutral, so I'm thinking it's not the neutral safety switch. Change the ignition switch? Any other ideas?
Thanks ~
Old Sep 26, 2014 | 4:20 PM
hippyspec's Avatar
Update.
Battery is good. Starter is good. I replaced the neutral safety switch. Also replaced the ignition lock as it was worn. Cleaned the grounds.
No joy. Turn the key, click, lights come on. Nothing else happens.
In looking at parts I see an ignition switch, which is also a cheap part, $15 or so. I might try that, but that's the end of throwing parts at it.
Any suggestions would be much appreciated, as I'm getting close to paying a mechanic.
Old Sep 27, 2014 | 11:08 AM
Did you check the starter solenoid?
Old Sep 27, 2014 | 7:40 PM
hippyspec's Avatar
It has a new starter, and I think that the solenoid was included in it as a unit. Am I wrong?
The neutral safety switch is not identical to the old one. It has two two-pin plugs plus one additional single pin that there is nothing to plug into. I took both back by the auto parts and they looked up the number on the old unit and the one I bought is listed as the direct replacement. I was planning to swap the old one back through to see if anything different happened.
Other than that all I see is the ignition switch. I replaced the ignition lock as it was worn and a bit wobbly. Once I get beyond that, parts start to get to ignition modules and other expensive bits. I'm sorta ok about a couple of parts under $20, but throwing more $70-80 parts at it is a non-starter.
ZChevyAK
Nov 13, 2015 6:45 PM
samsaridinc1500
Dec 8, 2014 11:01 AM
bracca
Jul 12, 2009 6:14 PM
FamilyOf5
Jun 11, 2008 2:56 PM
DarkAsylum
Nov 20, 2006 11:05 AM
