93 Silverado running rough
My 93 Silverado 5.7 tbi runs great when cold but when it gets to running temp it hesitates, almost seems to die but doesn't. Bogs and hesitates till about 2000 rpm. What could cause this?
Welcome to the forum....
If I recall correctly the 93 is throttle body injected with 2 injectors...
so you should have a throttle position sensor and the idle air control valve...
do you have any codes that are set or stored?
I will be checking what codes it has in the next couple days. Then I'll post them here. Thanks
slm_of_T90
March 21st, 2011 10:36 AM
jd512k
April 30th, 2008 10:41 PM
dave79
December 2nd, 2007 2:57 PM
