93 Silverado running rough
Old Dec 22, 2014 | 7:01 PM
93silverado5.7's Avatar
Default 93 Silverado running rough
My 93 Silverado 5.7 tbi runs great when cold but when it gets to running temp it hesitates, almost seems to die but doesn't. Bogs and hesitates till about 2000 rpm. What could cause this?
Old Dec 22, 2014 | 8:49 PM
Welcome to the forum....
If I recall correctly the 93 is throttle body injected with 2 injectors...
so you should have a throttle position sensor and the idle air control valve...
do you have any codes that are set or stored?
Old Dec 23, 2014 | 8:00 PM
I will be checking what codes it has in the next couple days. Then I'll post them here. Thanks
macmommy
Apr 22, 2020 1:23 PM
slm_of_T90
Mar 21, 2011 10:36 AM
jd512k
May 8, 2008 6:47 AM
jd512k
Apr 30, 2008 10:41 PM
dave79
Dec 2, 2007 2:57 PM
