94 k1500 HELP
Old Apr 18, 2023 | 2:06 PM
Hunter95's Avatar
Default 94 k1500 HELP
I have a 94 k1500 5.7 with ignition problems. It skips at idle the tach started jumping around only on idle and when you put it under a load like keeping speed on the interstate the valves start rattling after a few minutes them cylinders start misfiring then the ignition cuts in and off but if you coast it it’s comes back around. New plugs wires new distributor. I don’t know what else to do here can someone please help me as I’m about to just put a hei distributor in it
Old Apr 18, 2023 | 5:22 PM
Oldcat's Avatar
Ignition coil.
Old Apr 18, 2023 | 6:32 PM
Hunter95's Avatar
I’ve changed it too. Distributor plugs wire and coil all brand new. No change at all not even the slightest
Old Apr 23, 2023 | 3:44 AM
oilcanhenry's Avatar
I'd do a valve adjustment myself. You said you valves are rattling, so try that first.
Old Apr 23, 2023 | 10:41 AM
Rednucleus's Avatar
How many miles on your '94? Was this a sudden problem when it started or is it getting gradually worse?
Old Apr 23, 2023 | 6:51 PM
Hunter95's Avatar
it was a sudden problem. The truck has 238,000 miles the engine has 78,500 miles on it according to the paperwork that I have the valves start rattling like when you’re going up a hill a steep hill are pulling a trailer putting it under a load over here or something and you’re on it for a minute they start rattling you like it has too much ignition timing then it starts skipping and it starts with one cylinder and then a couple more then it’s like you’re cutting the ignition on and off but if you let off the gas for five seconds to coast it it comes back and it’s fine
crusher9
Oct 2, 2013 7:10 PM
94 k1500
Aug 31, 2013 6:01 PM
Chevy1500K20
Mar 1, 2012 12:15 PM
Amale97
Mar 1, 2012 3:09 AM
chevymike
Jan 28, 2012 11:51 PM
