94 Olds Hesitation
Old Feb 20, 2009 | 9:04 PM
dcoperator's Avatar
Default 94 Olds Hesitation
I've got a 94 Olds Cutlass Supreme w/3.1 engine and occasionally hesitates on takeoff. Just put a fuel pump and filter on it along with a pump relay. Runs good down the road but taking off at a light it "gasps" before going... Any thoughts would be appreciated.
Old Feb 22, 2009 | 1:40 PM
jwruss's Avatar
Carb rebuild.
Old Feb 22, 2009 | 6:51 PM
dcoperator's Avatar
Is there any rebuild to fuel injection?
Old Feb 23, 2009 | 2:18 AM
irdaneel's Avatar
Look for leaks first. Vacuum, air intake, etc. If air bypasses your air flow sensor it will confuse the injection system. The air flow sensor can also be dirty or malfunctioning.
Check your air filter and intake tubes for blockages.
Throttle body cleaner may help.
A less likely candidate is an O2 sensor.
Richdreck
May 29, 2008 1:18 PM
mikes86caprice
Apr 16, 2007 2:36 PM
mike78olds
Mar 9, 2007 10:01 AM
Big Pip
Jan 29, 2007 6:16 PM
zoideraserb
Nov 27, 2006 3:46 AM
