95 Tahoe 4WD problems
Old Feb 8, 2010 | 8:04 PM
jfgold's Avatar
Default 95 Tahoe 4WD problems
Hello and thanks in advance for your help! I am having problems with my 95 Tahoe going into 4WD. I replaced the switch in the top of the transfer case and the actuator motor and still no go. All fuses in the underhood fuse box are OK, is there a fuse located somewhere else that may be blown. New actuator does not move when shifted in/out of 4WD. Please help, snow is coming again!
Thanks,
Old Feb 8, 2010 | 8:27 PM
maxxman04's Avatar
open drivers door, should be another fuse panel on side/ end of dash. pull small panel off, should be a listing of fuse location/size/equipment it protects.
Old Feb 9, 2010 | 3:41 AM
jfgold's Avatar
Default Found the fuse!
Silly me, I am embarrassed to say that I finally found teh fuse. Must have been the actuator as the fuse did not pop when I replaced it. Thanks again all!
D Chevy
Sep 17, 2012 12:06 PM
04Greg
Mar 2, 2011 9:46 AM
vpbho
Nov 1, 2010 10:08 AM
waller2003
Oct 19, 2009 9:49 PM
DianaT
Nov 29, 2007 12:12 AM
