96 k1500 won't crank
Old Jan 19, 2015 | 10:56 AM
triton's Avatar
Default 96 k1500 won't crank
hey guys, I'm having bit of problem, 5.0 motor checked battery checked starter bench tested starter all is good. So I went to check out the ignition switch using a test light white wire and have power there, yellow wire to starter with the key in the on position when I put test light on it starter turns over when I turn key to start position I have power but it won't attempt to start with the test light applied only tries to crank with the test light connected in the on position. Do you guys think bad ignition switch
Thanks to all who reply
buddman
1988 - 1998 (GMT400)
Nov 21, 2017 8:25 AM
BlackZ71Silverado
Oct 19, 2014 5:11 PM
buddy@exxon
Jan 9, 2009 5:19 PM
calbers
Jan 22, 2008 5:06 PM
Lunchbox
K5 Blazer
Nov 25, 2006 1:14 AM
