K5 Blazer 1969-1994
Platform: Truck, GMT 400
88 k5 won't crank
Old Nov 9, 2006 | 6:36 AM
Lunchbox's Avatar
Default 88 k5 won't crank
I can't get my truck to crank. I have checked the fuel pump. I have also reaplaced the fuel filter, Engine Computer, MAP sensor, Fuel Relay, and any blown fused under the dash. The motor cranks right up when I shoot ether into it. What else could it be?
Old Nov 9, 2006 | 9:02 PM
70mopar's Avatar
Default RE: 88 k5 won't crank
check 2 make sure the injectors r getting a signal. check the union on the grounding side of the wiring harness (about 6 to 10 inches from the injector plugs). i've seen them corrode here and stop the signal from getting through.
Old Nov 15, 2006 | 2:50 AM
Tommygunz's Avatar
Same motor, same possible issue...
see link from suburban forum..
https://chevroletforum.com/m_13174/tm.htm
Old Nov 17, 2006 | 1:20 AM
70mopar's Avatar
Tommygunz, check that 'burb forum (https://chevroletforum.com/m_13174/tm.htm) for more input on this issue.
Old Nov 17, 2006 | 1:40 AM
Tommygunz's Avatar
touche'
Old Nov 21, 2006 | 5:47 AM
astroman's Avatar
hi! when i turn engine over with outer manifold off there is the injector unit i have removed pipes and poppet valves and let them hang loose and there is no fuel coming out of them when i turn over engine,i have a 12volt supply going to injector unit,i have replaced unit with one off another van and still no fuel coming out of pipes. thanks for help wayne.
Old Nov 24, 2006 | 1:13 PM
TheColonel's Avatar
Hey, i had the same problem. I checked everything but it ended up being the piece in the distributor cap. I cant remember what it was called but it is a small rectangle piece. Check that and it could fix your problem. My 88 K5 started choking and then it would not start. I checked the same stuff you did and finally figured it out. Hope this helps.
Old Nov 25, 2006 | 1:14 AM
70mopar's Avatar
it's called an ignition module. check the link i posted from the 16th of Nov., deals with same issue.
spiderpig773
Dec 30, 2012 10:23 AM
Prat'nWhitney
Aug 6, 2009 10:19 AM
Shanedmoore
Jan 24, 2009 1:26 PM
buddy@exxon
Jan 9, 2009 5:19 PM
calbers
Jan 22, 2008 5:06 PM
