96 Tahoe electrical woes
Old Jul 26, 2007 | 6:23 PM
knucklehead9's Avatar
Default 96 Tahoe electrical woes
Help! My 96 Tahoe will not start. I suspect the ignition switch,but the symptoms are confusing me. When the key is in the RUN position, the following systems are not powering up: Daytime running lights, fuel pump primer, all functions of fuse #16(turn signals, back-up lamps, BTSI solenoid) fuse is good, fuel temp oil batt guages, dashboard start-up (bulb test), seat belt/key in warning chime. Other electrical functions that only work with the key in RUN are still functional: Sound system, wipers, climate controls, power windows. The starter engages when the key is turned to start, but no start up.
Old Aug 12, 2007 | 1:11 PM
LILSUTHERN's Avatar
Default RE: 96 Tahoe electrical woes
Just out of curiosity did you recently have a key made? did you know that a key new key not from dealer will allow your tahoe to function in always except to crank for theft provention?
Old Aug 12, 2007 | 7:00 PM
golfer's Avatar
ORIGINAL: LILSUTHERN
I don't believe they had immoblizers installed till 98 and it was the PasslockII system that doesn't have anything to do with the key itself.
AZCardsAndIndyColtsFan
Jul 5, 2013 10:33 AM
Andrew_350
Sep 10, 2006 12:03 PM
ShadowDrake
Aug 5, 2006 3:40 PM
fredtz
Feb 28, 2006 11:05 PM
Soulcrusher
Jan 24, 2006 10:17 PM
