96 tahoe no start
Old Feb 1, 2008 | 5:15 PM
andrew4g63's Avatar
Default 96 tahoe no start
i have a 96 tahoe with the 5.7 that wont start. it stalled while driving and now wont start. i checked for spark by pulling a spark plug wire boot off and grounding it to metal. it seemed to have no spark. also it did not have a check engine light when cranking so i replaced the crank position sensor. changing the crank sensor made the check engine light come on when cranking but still no start. can someone please give me some ideas
Old Feb 3, 2008 | 1:00 PM
dewey's Avatar
Default RE: 96 tahoe no start
Just to be sure, I'd take a plug-wire loose, put a known good plug in the boot, lay metal part of plug on metal ground, have a helper crank the vehicle, watch for spark at the tip of the plug. Or you can use a cheap spark tester from the autostore.
You could also take the coil wire loose from the dist.cap, hold the wire close to engine ground, have a helper crank it, see if spark jumps. If you have spark there, but, not at the plugs, then I think the problem is the cap or rotor.
If you don't have spark anywhere then check the coil primary terminals, see what's going on.
bracca
Jul 12, 2009 6:14 PM
Thermool
Jun 20, 2009 6:41 PM
wildboy74ss
Apr 1, 2009 5:10 PM
izod
Feb 14, 2009 2:42 PM
