Help! for poor daughter's tired car
Old Feb 1, 2008 | 11:36 AM
krosspen's Avatar
Default Help! for poor daughter's tired car
My daughter’s beater overheated. I THINK the thermostat stuck closed, and the overheating cause two pin hole leaks in the radiator shroud adjacent to the upper radiator hose. Guess there isn't much radiator repair these days and we're talking $250 for a new radiator installed.
These are pin holes....
IS IT POSSIBLE TO USE SOME EPOXY or other stuff to stop the leak at these holes instead of replacing the whole thing in my poor daughter's clunker?
I am thinking the thermostat is stuck closed cause although it was out of water I could only get a little over a gallon of water poured into the overflow tank. When it got hot, there was still pressure at the overflow tank opening and it was still full...yet it was HOT. Seems like the water couldn't flow into the engine, making more room for more liquid. ** Does my thinking seem reasonable? THANKS FOR ANY HELP!
Is this a hard thermostat to change, or ok to get at??
Old Feb 2, 2008 | 7:21 AM
slc10844's Avatar
Default RE: Help! for poor daughter's tired car
Need vehicle information?
Old Feb 3, 2008 | 9:58 AM
jffgin's Avatar
I've heard of people using body filler to temperary fix radiators.
Old Feb 3, 2008 | 4:05 PM
BigScott5150's Avatar
maybe try some JB Weld. i once had a motorcyle and accidentally dropped it off the center stand when i was changing the back tire. it cracked the block and caused an oil leak. after draining it i put the jb weld on and it held very well.
Shinare
Sonic (Aveo)
Feb 13, 2021 9:16 PM
in2pro
Cobalt
Jun 17, 2012 1:47 PM
12 pointer
Jun 25, 2010 6:16 AM
ashortkid
Dec 27, 2008 1:06 PM
hatleyjm2000
Mar 25, 2008 10:31 AM
