97 Chevy Tahoe 5.7L wont start.
My 97 Chevy Tahoe quit running a little while ago. I replaced the fuel pump, fuel filter and the pump relay under the hood but motor still isn't getting fuel. What else could be the problem? Am I overlooking anything?
You need to see if the injectors are getting a pulse, that requires a cheap tool looks like a pick with a ground clip. I cannot remember the correct name for it, but ground the clip, and put the point into the plug wire . If the injector is getting a pulse, the light in the handle will light when cranking.
hme1
February 1st, 2012 9:07 AM
