97 K2500 Pickup Stalling Issue
Old Feb 21, 2009 | 12:45 PM
misledmunkie's Avatar
Default 97 K2500 Pickup Stalling Issue
4wd 6.5l Diesel
It occasionally stalls out after driving for extended period of time. I'm also getting white smoke from the tailpipe and it struggles to get over 40mph.
But, if I pull over and shut it down (while all these problems are occuring) and start it right back up it runs like a dream and gets up to higher speeds no problem but this only lasts for a couple of minutes.
Old Feb 23, 2009 | 2:36 AM
irdaneel's Avatar
Check your fuel! Change your filters and especially check your water separator. White smoke is usually associated with water. Water also compresses more than fuel, causing less fuel to inject, much like air in a brake system.
Water will also rust your injection pump, a very, very expensive repair!
Old Feb 23, 2009 | 7:16 PM
replaced the fuel filter, checked the water seperater. could a lift or injector pump cause this problem?
epagidas
Dec 9, 2023 8:58 PM
Schveb
Sep 18, 2017 9:05 PM
river1
May 19, 2012 1:15 PM
jrsavoie
Feb 24, 2010 2:38 PM
buijon
Jun 28, 2008 12:26 PM
