99 Chevy cavalier master cylinder
Old Nov 5, 2017 | 10:19 PM
Charles Shaheen's Avatar
Default 99 Chevy cavalier master cylinder
I recently got a 2.2 cavalier and the guy said brake lines needs fixed so I put fluid in master cylinder and pumped brakes they go straight to the floor I did that a few times and went to check it out no leaks but the master cylinder is still full of fluid idk what it could be any ideas??
Old Nov 6, 2017 | 3:50 AM
oilcanhenry's Avatar
Air in the lines, bad lines, bad seals. Just putting BF in the MC isn't going to take the air out.
Old Nov 6, 2017 | 7:51 AM
I agree, there is air in the lines and master cylinder. Bleed the brakes and then look for leaks. There has to be a reason for the master cylinder being out of fluid.
Old Nov 6, 2017 | 8:19 AM
The master cylinder is not out of fluid the fluid stays in the mc
Old Nov 6, 2017 | 11:55 AM
You said you put fluid in the master cylinder. Even if it wasn't empty it still has air in the system and needs to be bled.
