AC suddenly stopped working
Old Sep 21, 2008 | 6:17 PM
sloopy3's Avatar
Default AC suddenly stopped working
I have a 1999 Chevy Prizm. The AC was blowing cold and working fine and all of the sudden one day it stopped blowing cold. Happened suddenly, which makes me think its not a refridgerant issue. I checked the fuse to the AC under the hood and it looked fine. The green light is on when the AC button is pressed in, but I don't think its working. I know there is a clutch that pops out to allow for the compresser to turn via the belt. I can't tell if it has popped out or not. Is it likely that the clutch assy is bad or would it likely be the compressor?
Old Sep 22, 2008 | 4:39 PM
Deteoni's Avatar
Default RE: AC suddenly stopped working
ORIGINAL: sloopy3
Hey sloopy,you got to verify that the A/C clutch is (or is not) workingfirst. Confirm that it is turning with the A/C on. Putting your climate control on 'Defrost' should cause it cycle on and off so you can stand there and watch it to see if its turning.
Old Sep 23, 2008 | 7:16 AM
jackyshaikh's Avatar
Hi sloopy3
You mention its stop working all of a sudden right? Did you checked A/C Compressor belt ( broken or jump out of compressor ) just a thought.
Old Jun 10, 2015 | 7:50 AM
Ted R.'s Avatar
Sorry to bump such an old thread, but my mom has a '99 Chevy Prizm and as of 1-2 weeks ago, the A/C no longer works. I saw the replies suggesting to check the A/C clutch and the belt, but I have no idea where those things are located or what to look for. Can someone provide some detailed information (and possibly photos) so I may troubleshoot the problem?
mentalmom
Nov 26, 2008 6:05 PM
texxan1
Sep 5, 2007 8:24 PM
rjoos
Jun 28, 2007 6:59 PM
kds210
Feb 16, 2007 10:17 PM
vyslouzil
Sep 25, 2006 11:23 AM
