AC will not calibrate correctly after replaced bad blend door.
Old Aug 21, 2019 | 10:37 AM
mmerten1973's Avatar
Default AC will not calibrate correctly after replaced bad blend door.
2004 Tahoe, 2wd, dual AC. driver side blend door was bad, replaced with new part. now drive side will not blow cold air more like warm, every where else is cold? did the calibration like the videos said no success? Not sure what my next step is to check.
MIke
Old Aug 21, 2019 | 2:21 PM
Irish_alley's Avatar
I'm here for the party
could be low on freon
Old Aug 21, 2019 | 2:25 PM
Feron is good, pressure switches working, clutch in coming on when AC turned on still ???
Old Aug 21, 2019 | 2:28 PM
on my 04 imp (dual climate control) the passengers side would be ice cold but drivers side would be warm. i could never fit a manifold gauge set on it due to the low side being too close to the firewall so i had to use the single gauge, the pressure was reading "good" added another can and the pressure gauge was still in the good side and both sides are now ice cold
Old Sep 8, 2019 | 3:47 AM
William Hepfner's Avatar
I am having this same exact problem . I did all the calibration test and still no luck for me. Im honestly to the point where I think I’ll have to take my AC evaporator out and clean it out sense I think it may be causing a blockage of some sort . But before I do that I’m still doing everything I can to get the new or even my old actuator to work bcuz my driver side blow hot as hell and this Texas heat ain’t no joke ��
