adding strobes & work lights
Old May 2, 2025 | 7:38 PM
bikernut's Avatar
Default adding strobes & work lights
adding a headache rack with strobes & work lights to my 2016 Silverado 2500hd WT. I have gotten a upfitter switch panel and the added wires for it. Now it says these added wires are for grounding the item I want to add so where do I ground these to when adding the lite(s). Where does the switch get its power from and how to I wire the added items? I found something about a relay under the hood in electrical panel don't understand this so can someone give me precise wiring directions as I don't want to burn down my vehicle?? thanks all
Old May 4, 2025 | 10:13 AM
Welcome from Florida. The ground wires connect to any grounded metal parts. You need to decide if you want the lights to on only with the key on or anytime! I would rather add a relay than to mess with anything in the fuse box. This is how to wire and added relay. Terminal 30 should get it's 12 volts from a source that can handle the amps required by your added lights and be fused. Terminal 87 is from the switch and should get it's 12 volts from a switched source or an all-time power on source.
5Pcs Automotive Relay 12V DC 30A 4 Pin 4 Wire Interlocking Relay Socket Kit♡ - Picture 1 of 12
Old May 5, 2025 | 1:38 AM
bikernut's Avatar
thanks for the info.
can and would you give me more details on where these terminals are and how to add a relay and what part(s) number of said relay?
it says picture # 1 of 12 I don't see any pictures and they I bet would be of great help.
thanks from New Hampshire
William Diegelman
Oct 27, 2016 11:22 PM
Brainsqueeze
Jul 17, 2015 11:16 AM
lonewolf1226
May 3, 2012 9:30 AM
capucine
Uplander
Apr 10, 2010 4:00 PM
sixpack_sid
Feb 4, 2008 10:57 AM
