Advanced starting issue!! please help!!
Old Dec 13, 2016 | 7:51 PM
  #11
visual is not good enough. you need to put a gauge on it and see what the fuel pressure is doing.
one of the six other injectors may be leaking down. You want you injector flow rates to be balanced so if you find a fuel pressure leakdown condition from the injectors...replace the other 6.
all the starting issues you are having are textbook injector leakdown symptoms. the engine is basically flooded after the fuel pressure leaks down into the cylinders.
If it were me, I would put a gauge on the fuel rail, prime the system and check for leakdown. if there is leakdown, block off the feed, prime and recheck, if it is still leaking down, block off the return, prime and recheck. if its still leaking down, its the injectors as you have already ruled out the fpr.
Old Dec 13, 2016 | 8:56 PM
  #12
2000SltGuy8605's Avatar
Ok I'll try that thanks for the help guys!
Old Dec 31, 2016 | 10:55 AM
  #13
In need's Avatar
Default Help us both
So if there is leak down does that mean replace all the injectors or do all the o rings
Old Dec 31, 2016 | 10:14 PM
  #14
if after clamping off the return and supply lines and it still leaks down...and the fpr is dry...the injectors and o-rings should be replaced.
Old Jan 1, 2017 | 8:05 AM
  #15
In need's Avatar
Default Fire
To late,truck started on fire,garage burned to the ground and truck is now gone
Old Jun 11, 2017 | 1:13 PM
  #16
Jacob Killam's Avatar
it could be the coolant temp sensor. normally it works the other way round but if the sensor is stuck reading low it could be dumping too much fuel into the engine when it's warm. when the engine is cold it needs more fuel to start up so the computer takes care of that. if the sensor is stuck cold for some reason it's going to tune the engine to the assumption that the engine is cold and dump too much fuel to start up when the engine is warm. it would explain why the engine starts fine when it's cold and starts and runs like crap when it's warm. I'm kinda new to the Chevys but a lot of other manufacturers use separate temperature sensors for the signal going to the PCM and the gauge on the cluster. that means the gauge on the cluster could be reading fine while the sensor to the PCM could be junk and sending the computer the wrong info.
